Need help with RAID bios configuration
DanoBull
My boot settings got screwed up somehow while optimizing with tuneup program. the couple days before this happened I was getting a ckdisk upon startup and an error on step 3, so i ran tuneup utilities program, and haven't been able to get past windows screen before blue screen with stop 0x0000007f keeps coming up. i have a msi k8n neo4 platinum/sli mobo(nvidia nforce 4 sli chipset based) with a amd athlon 64 x2 dual core 4200+ DDR333. when I go into bios, it shows:
Standard CMOS Features:
IDE Primary master: Maxtor CALYPSO(harddrive)
IDE Primary slave: NONE
IDE Secondary Master: PCRW804(Philips cdrom that hadn't been working)
Ide Secondary Slave: Memorex DVD16+/-D (burner and cdrom that i've been using)
IDE Third Master: WDC WD360GD-00FLC(western digital hard drive)
IDE Fourth Master: WDC WD360GD-00FLC(western digital hard drive)
IDE Fifth Master: NONE
IDE Sixth Master: NONE
Floppy Drive A: NONE(I don't have a floppy drive installed)
Halt ON: All Errors
Advanced BIOS Features:
Quick Booting: Enabled
Boot to OS/2: NO
MPS Table Version: 1.4
Full Screen LOGO Display: Enabled
Security Option: SETUP
Boot sequence:
1st Boot Device:Hard Disk
2nd Boot Device:CDROM
3rd Boot device:Hard Disk
Boot from other device: ENABLED
Hard Disk Boot Priority:
1. Ch0 M. :Maxtor CALYPSO
2. CH2 M. :WDC WD360GD-00FLC0
3. CH3 M. :WDC WD360GD-00FLC0
4. Bootable Add-in Cards
Advanced Chipset Features:
SLI Broadcast Aperture: DISABLED
Integrated Peripherals:
USB Controller: Enabled
USB KB/Storage Support: Enabled
USB Mouse Support: Enabled
nVidia MAC LAN: Auto
nVidia MAC LAN ROM: Disabled
Onboard IEEE1394 Controller: Enabled
Marvell GigaBit LAN: Enabled
Marvell GigaBit LAN ROM: Disabled
OnBoard CREATIVE AUDIO: Enabled
OnBoard SiI3132 RAID: Enabled
Onboard SiI3132 Mode: SATA(can switch to RAID?)
I/O Device Configuration:
Onboard FDC Controller: Enabled
COM Port 1: 3F8/IRQ4
IR Function Select: Disabled
Parallel Port: 378/IRQ7
Parallel Port Mode: SPP[/flash]
IDE Devices Configuration:
OnChip IDE Channel0: Enabled
OnChip IDE Channel1: Enabled
IDE DMA transfer access: Enabled
SATA1/SATA2: Enabled
SATA3/SATA4: Enabled
nVidia RAID Config:
RAID Enable: Enabled
IDE Primary Master RAID: Disabled
IDE Primary Slave RAID: Disabled
IDE Secondary Master RAID: Disabled
IDE Secondary Slave RAID: Disabled
SATA1 RAID: Disabled
SATA2 RAID: Disabled
SATA3 RAID: Disabled
SATA4 RAID: Disabled
That's my complet bios other than Power Management, PnP/PCI Configurations, Etc.
I hope it wasn't too long winded, but my memory all checked out ok, and I have checked all my cables, I think it's got to be something in the configuration......
Please let me know what you think.
Thanks,
ch33zw1z
39,755
20,327
Check which ports the 2x36GB Raptors are plugged into, and check the manual for which controller (SiI3132, or Nvidia) the RAID should be on. What make/model mobo is it?
DanoBull
MSI K8n Neo4 Platinum/sli mobo. the 2 hard drives are wired into the sata serial ATA ports 1 and 2
ch33zw1z
39,755
20,327
Product page
So which controller do you need to enable the drives on, that's the question it seems..have the manual handy?
edit, from the product page, link updated
On-Board IDE/SATA
? An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
? NV RAID supports 4 SATA II ports (SATA1-4). Transfer rate is up to 300MB/s.
? NV RAID (Software)
- Supports up to 4 SATA plus 2 ATA 133 Hard drives
- RAID 0 or 1, 0+1, JBOD is supported
- RAID function work w/ ATA 133 + SATA H/D or 2 SATA H/D
? Silicon Image's SATARAID supports another 2 SATA II ports. Transfer rate is up to 300MB/s
- RAID 0 or 1 and JBOD groups are supported
- Support up to 2 SATA devices connected to a single controller
Nvidia controller it would seem..
