- Feb 26, 2014
- 27
- 0
- 61
Hi there everybody,
I'm new here and this is my first post so once again welcome. Being OC newbie I hope I can learn a lot from you guys and am glad to be here. If you find my grammar and style a bit stiff or faulty please do forgive me - English is not my first language. I'm hoping some of you out there can help me with my first steps in OC. Here are my system specs and my problems:
- mobo: GA-M56S-S3
http://www.gigabyte.com/products/product-page.aspx?pid=2607#ov
Chipset:
- Northbridge NVIDIA nForce 560 rev. A3
Southbridge NVIDIA nForce 560 rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2 GBytes
Channels Dual
Memory Frequency 401.8 MHz (CPU/5)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 24
Command Rate (CR) 2T
- CPU: Athlon 64 X2 3800+
CPUID F.B.2
Extended CPUID F.4B
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
Core Speed 2009.2 MHz
Multiplier x Bus Speed 10.0 x 200.9 MHz
HT Link speed 1004.6 MHz
Stock frequency 2000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 10.0x
Max VID 1.400 V
BIOS:
vendor Award Software International Inc.
version F4e
date 03/04/2008
ROM size 512 KB
GPU processor: GeForce GT 610
Driver version: 334.89
Direct3D API version: 11
Direct3D feature level: 11_0
CUDA Cores: 48
Core clock: 810 MHz
Shader clock: 1620 MHz
Memory data rate: 1000 MHz
Memory interface: 64-bit
Memory bandwidth: 8.00 GB/s
Total available graphics memory: 2815 MB
Dedicated video memory: 2048 MB DDR3
System video memory: 0 MB
Shared system memory: 767 MB
Video BIOS version: 75.19.55.00.10
IRQ: 16
Bus: PCI Express x16
Device Id: 10DE 104A 26193842
Part Number: 1310 0004
Windows Version Microsoft Windows 7 (6.1) 32-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
My objective is to OC CPU to 2400MHZ clock. I understand that the most expedient way to do this would be by raising FSB in the Bios. Athlon 64 X2 3800+ has a 10x multi. Therefore raising my FSB to 240 would result in a 2400MHZ clock. The problem is I don't know how to do this and cannot find this option in the Bios or maybe I don't see it because it's named differently. On my ancient K7VT4A Pro the CPU FSB frequency was determined by jumper-setting on motherboard. Here I cannot find such thing. There is something in the Bios called MB Intelligent Tweaker(M.I.T.) offering the following options to change but I still don't see any FSB tweaks here:
CPU Frequency [200]
PCIE Clock [100Mhz]
CPU Clock Ratio [Auto]
Robust Graphics Booster [Auto]
Chipset Voltage Control [Normal]
DDR2 Voltage Control [Auto]
CPU Voltage Control [Normal]
Normal CPU Vcore 1.3500V
I will immensely appreciate any help from you. I know my system is weak and it is time for a change but I'm flat broke at the moment and overclocking the CPU to 2400 MHZ is my only hope to play GTA IV at all.
- mobo: GA-M56S-S3
Chipset:
Memory Type DDR2
Channels Dual
CPUID F.B.2
Extended CPUID F.4B
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
FID/VID Control yes
Max FID 10.0x
Max VID 1.400 V
BIOS:
version F4e
date 03/04/2008
ROM size 512 KB
CUDA Cores: 48
Core clock: 810 MHz
IRQ: 16
CPU Frequency [200]
PCIE Clock [100Mhz]
