change the memory:CPU ratio
Hi there again,
I'm reporting some developments. I kept overclocking CPU Frequency [240] in small increments of 0.2 with the following values:
PCIE CLOCK - 100MHZ
CPU CLOCK RATIO - AUTO
ROBUST GRAPHIC BOOSTER - AUTO
SYSTEM CLOCK - MANUAL
MEM CLOCK - DDR 533
DRAM CONFIGURATION:
DDRII TIMING ITEMS - MANUAL default of 800
CAS# LATENCY - 5T
RAS to CAS R/W - DELAY 5T
ROW PRECHARGE - TIME 5T
MIN RAS ACTIVE TIME - 18T
1T/2T COMMAND TIMING - 2T
TwTr COMMAND DELAY - 3T
TrFc0 for DIMM 1 - 105ns
TrFc2 for DIMM 2 - 105ns
TrFc1 for DIMM 3 - 75ns
TrFc3 for DIMM 4 - 75ns
WRITE RECOVERY TIME - 6T
PRECHARGE TIME - 3T
ROW CYCLE TIME - 24T
RAS TO CAS DELAY - 3T
BANK SWIZZLE MODE - ENABLED
CHIPSET VOLTAGE CONTROL = NORMAL
DDR2 VOLATAGE CONTROL - AUTO
CPU VOLTAGE CONTROL - 1.4000V
Normal CPU Vcore 1.3500V
K8 <-> NB HT SPEED - 4x
K8 <-> NB HT WIDTH - 16
At the CPU Frequency [256], upon completing the benchmark, IntelBurnTestV2 told me that system was unstable. I almost cried. It was so close to having 4800+. I came back to 254 run the Intel thing again and got congrats that everything was OK. So now I'm stuck and don't know what to do next. If I may I'd have a few questions:
- what is my CPU CLOCK RATIO (now set on Auto) and can I set it manually:
x5
x5.5
x6
x6.5
x7
x7.5
x8
x8.5
x9
x9.5
x10
How can I tell which ver of Athlon 64 X2 3800+ wattage-wise I have, I know the code is on the CPU itself but other then opening the case and taking it out?
AMD Athlon 64 X2 3800+ 2000MHz 512KBx2 Windsor 90nm F3 65W 2000
AMD Athlon 64 X2 3800+ 2000MHz 512KBx2 Windsor 90nm F2 89W 2000
AMD Athlon 64 X2 3800+ 2000MHz 512KBx2 Windsor 90nm F2 65W 2000
AMD Athlon 64 X2 3800+ 2000MHz 512KBx2 Windsor 90nm F2 35W 2000
And then is there any way I can make it to 4800+? OC is great, it's a high, it's like sex only better and thanks to you guys I'm hooked. Here are new screens:
https://drive.google.com/folderview?id=0B8tfWk0vzmviVEUwdlZGamJlSm8&usp=sharing
