D darketernal Member Sep 18, 2006 53 0 0 Sep 21, 2006 #2 for some reason the mehrunes plug in does not start a quest, all the other plugins work
apoppin Lifer Mar 9, 2000 34,890 1 0 alienbabeltech.com Sep 21, 2006 #3 is it installed properly and checked in Data Files? you DO have the latest patch? finally, if a REinstall does not work, contact Bethesda tech support
D darketernal Member Sep 18, 2006 53 0 0 Sep 22, 2006 #4 im pretty sure i have the latest patch, 1.1 right?, but im not sure if its installed, and also for some reason the installer doesnt make any progress.
apoppin Lifer Mar 9, 2000 34,890 1 0 alienbabeltech.com Sep 22, 2006 #5 uninstall and reinstall oblivion, the patch and then the plugin. just make sure you don't lose saved games --or plugins [you can't re-d/l them after a certain time] . . . also check your HD and defrag if necessary [especially just before you reinstall] good luck edited
