lehtv
- Dec 8, 2010
- 11,897
- 74
- 91
What do you mean when you say its in push or pull configuration? Are you referring to which side of the radiator it's placed (but with the fan facing the same direction)?![]()
Yes, that's what I'm referring to. If the fan draws air through the heatsink, it's 'pull', if it pushes air through the heatsink, it's 'push'.
I just saw that Corsair recommends that the H90 is installed as intake, which makes sense, but isn't that a little strange to have an intake in the rear?
Yes, that way you get optimal performance from the heatsink. If it draws air through the back, it's drawing in cool air which means it'll perform better. But the downside is it's pushing warm air into the case, and you have to have a way of exhausting it. Personally I'd just install it to push air out of the rear and deal with the performance disadvantage, it just makes things easier.
Then I'd have no exhaust at all unless I installed fans in the top of the case (or the H90). I saw a test (http://www.tomshardware.com/reviews/water2.0-extreme-kraken-x40-hydro-h90-elc120,3434-13.html) where there is a quite significant difference in cooling performance between intake and exhaust on the H90.
I bet the intake slot for the cooler isn't filtered to keep dust out...
I also just saw a new Coolermaster case, Silencio 652 (http://www.coolermaster.com/product/Detail/case/mid-tower-silent-series/silencio652.html) - this looks really nice I think - and it's cheap, but I can't really find much information about it - do you have any knowledge about this case?![]()
Typically Silencios are basically budget versions of better quiet cases: fewer features, more plastic, worse cooling performance.
That Silencio 652 seems to be the highest end case in the Silencio series, and it shows. It looks like it's the only silent-marketed case that supports 180mm fans, and in four different slots no less. It even comes with one. The one disadvantage it has compared to R4 though is that in its stock fan configuration, it's going to be louder: there's no integrated fan controller.
It looks nice but I'd wait for reviews before buying it. I hope Anandtech reviews it.
