Hi,
I am about to buy a new gaming/allround PC and I am quite a bit in doubt about some of the components. So far I have considered the following:
CPU: Intel i5-4670k
CPU-cooler: Corsair H100i or H110
Motherboard: Asus Maximus Hero
Memory: Corsair Vengeance Low Profile 2x4 GB 1600 MHz (CML8GX3M2A1600C9R)
Graphics card: MSI GeForce 760 2GB (Twin Frozr IV)
PSU: Corsair RM650 or Seasonic G-650
SSD; Intel 530 Series 180 GB
HDD; WD Blue 1TB (WD10EZEX)
Case: Corsair 750D or 550D or maybe Antec P280
Optical drive: Lite-On iHAS324
Im mainly in doubt about the case and cpu cooler, and a bit about PSU as well.
Id like my computer to be quiet, but I dont want to run into problems with too much heat. I quite like the design and features of the 750D, but I dont know how loud it will be compared with a Corsair 550D or Antec P280? I wont be able to block the top vent off (I will place the H100i or H110 here), so I guess some of the noise dampening of the 550D is lost due to this.
As for the cooler I am not sure if I should go with an H100i or H110. I see that the H100i got some inbuilt Corsair Link stuff, but Id actually like to avoid this and just control the fans with the motherboard, just to keep it simple but then I should perhaps go with the H110 as it doesnt have this Corsair Link? They are identically priced where I live.
Finally the PSU, do you think this will be ok for this system? Would you go with Corsair or Seasonic (the Seasonic is more expensive and not fully modular though)? Would it be enough if I later went for another 760 for SLI (not very likely though)?
I hope someone can help me out a bit, thanks in advance
CPU: Intel i5-4670k
