need help with ebay!!!
if u are the high bidder is there anyway to reduce your max bid???
some full put too much on shipping so i want to reduce my max bid to compensate
Exceptional Circumstances Only
There are, however, a few exceptional circumstances under which you may retract a bid. These are if:
You accidentally enter the wrong bid amount. For instance, you bid $99.50 instead of $9.95.
Note: If this occurs, re-enter the correct bid amount immediately after you retract your bid. If you do not place another bid, the retraction will be in violation of eBay's policy and could result in your suspension.
ah well its not a big deal...just wondering...cause its $15 shipping on paper...
i have the high bid right now, but my max i would reduce by like $10 if i could....but like i said, not a big deal
yeah, you have to fill out a Bid Retraction form. It's kind of hard to find (eBay does this on purpose) but if you look through eBay help and type in "Bid Retraction Form" or "Retracting a Bid" you should find it.
You're really not *supposed* to do it on things you bid a bit too high for, but I've done it a few times. Make up a good excuse, however, when you put your comments in. I usually do something like "Misread Auction" which I'm sure you can do too.
EDIT: of course you could always just say "I typed the wrong number in"
speakng of which i read the gheyest thing ever on ebay today...for angels tickets...they included shipping even if u wanted to pick it up at will call...so i specifically am making them ship it now...mofo's
As a seller myself... allow me to stress to you to learn the following tip NOW:
Whenever you think about bidding on an item, read and carefully re-read the ENTIRE auction description (so you don't later realize that they're charging more than you want to pay for shipping, etc...). Bids are final... so ask the seller any questions you may have before placing that bid.
hey man i aint never back outta a bid i made...i was just wonderin if i could lower my max, which the auction hasnt gotten up to...since i cant...im fine with it...i dont back away from what i put down
