Need help with easy math problem.
SP33Demon
Ok this is really simple, need to know how many numbers would be missing from 0 to 999 counting by 3, for example 0,3,6,9,12. It's been awhile since I did this and I forget the equation (15 years since basic math haha).
Thanks.
ummm unless im looking at it wrong would it just be 666?
999/3 = 333
999-333=666
hope this helps..
l8rz,
~miller
edit* add 1 to the anwser for zero
334
There are exactly 999 numbers from 1-999 so there are 333 number in that range regardless of position. Then you just add the 0 on to that to get 334.
Edit: oops, misread. 1000-334 = 666 ( :evil: )
Thanks guys! I got the same answer [(999/3) + 1], but just wanted to be 100% since this has to be perfect for some code I'm doing.
~Rob 🙂
