- Feb 1, 2017
- 3
- 0
- 6
So I've been trying nearly everything to get this chip further, but no matter what I do I can't get past 114 bclk which gets me to 3990 Mhz. Which isn't even that huge of a performance bump because at stock the cpu will boost to 3800 Mhz on all cores as long as your cooling is decent although it doesn't like to boost OC'd. So other than just under 200 Mhz on core my only other real benefit is I can run my 2666 DDR3 closer to it's rated speed and the NB might be running faster but I can't tell for sure since I can't find anything in CPU-Z that correlates with the frequency shown in the bios. Also the only program that can get temps from my motherboard is AI Suite and it only gets the "CPU temp" reading and the motherboard temp reading and I'm not sure I can trust those because it shows my cpu not even getting to 50c under load when it's drawing above 1.53v. Anyways my specs are: https://pcpartpicker.com/list/nyLCgL and my BIOS settings are: http://imgur.com/a/cKJEN
