Need Help with Cable Run
Penth
933
OK, I've got a cable running from my computer room (top floor) up to the attic and down two floors to my basement. I had the cable working fine yesterday but decided to have the cable go to a keystone jack in the wall instead of having a hole in the wall with the cable just coming out and going into the router. So I wire it up and it doesn't work. I put the cable tester on it and I get the following
1&2 = Green Light With 7&8 = Red Light (reversed)
3&6 = Green Light
4&5 = Green Light
7&8 = Green Light
I don't understand how I can have 4 green lights and one red light. Is it a short in the cable or something (I hope not as the attic has since been filled with blown-in insulation and it was complicated enought to run the wire in the first place.
Rapidskies
1,165
I would venture a guess that your jack is not wired correctly or the patch cable running from your jack to your pc is a problem. Test both runs of cable seperatley and then take another look at your jack.
Penth
933
The patch cable from the jack to the pc is brand new and purchased (not home-made). It tests out fine. I've checked and rechecked the jack. If I take either 7 or 8 out of the jack (the brown and brown with white) then 1&2, 3&6, 4&5 are all green as well.
OK, I've removed some possible problems. If I unwire all cable from the jack and only plug in 7&8, I get a green light when it would normally flash for 7&8 and then a red light (for what would probably be when it was flashing with the green 1&2 that is now disconnected)
casper114
814
That's no fun, I've been there. I really hate to tell you this but with all that testing and you're getting wierd results it may be the cable itself. Have you tried cutting back a few inches and crimping a new end on the available sides?
Penth
933
yeah, I've cut back about 8-10 inches on one side and probably 6 inches on the other. I don't have a ton extra to spare on either side, so I'm trying to keep it to a minimum in case there is any hope for this cable. I really don't want to try to run another. I think if I try connecting a new one to the old one it wouldn't pull through the house very easily.
