Need Help... With A7V
Saraivex
Well, here's the prob... I have a A7V and I bought a duron 800, and a Super Orb(1,5 Ghz. The Duron didn't arrived yet and the the 1,2 Ghz Tbird is so low priced now...
So I need to now what is the max socket A cpu my mobo can handle, eve the ones to come, like palomino from AMD. So I can have a decision on what socket A to buy(depending on my board possibilities)
If possible give me answers like this:
Tbird - x Mhz
Duron - X Mhz
Palomino - x Mhz
Dulanic
9,969
592
It will handle 12.5X multiplier currently.... Im sure they will change that to higher if new CPUs come out.
chiwawa626
12,013
u can probably buy 1250 or more buy using 12.5 x 1?? fsb
but sure a a7v will run ur 1200 tbird
Saraivex
I heard that a 1,5 Ghz AMD cpu is coming soon, so I wonder if a 1,2 Tbird with a Asus V7700 Gts2 64 MB will be enough to keep this up for at least 2 years or is it better to wait for those 1,5 Ghz cpu?
And by the way what is the best RAM for this system with the A7V.(I was thinking in a sdram dimm of 256).
Tks for you help guys/girls
