- Jun 30, 2000
- 7,809
- 0
- 76
Hi all,
I am new to this overclocking thing.
When I purchased the used MB/ cpu, it came with everything set in the bios already overclocked to 3000+. Did not want to push it since it had the stock hs/f combo.
Well, I got a new sk-7 heatsink and redid the thermal compound on the cpu with AS Ceramique. Reinserted the cpu and it tells me a new cpu is installed and to go into bios to setup. Originally had the settings of 200fsb x 11.5 at a voltage of 1.725. I tried to reinput those settings and reboot but it stops there. Is there something I am missing??? Running at default now.
Also the 80mm fan that I have on the sk-7 is very loose with the wires that attached to it. Anyone worry that it will fall off??? How are you guys keeping it on or securing it more tightly??
LMK
LMK
