Need help with a shirt description
Can you link us to the product?
EDIT : My initial thought is that it's stitching is of better fitting quality, meaning it would rest better on your shoulders/around your arms, etc. I don't believe it has anything to do with size.
Links to AE.com have session IDs in them, probably won't work. I'll show the whole description:
A premium-quality garment. The highest standards of appearance. Made of superior cotton fabric with a new fit that puts it a cut above the average shirt. Removable tabs in the collar create a clean, crisp shape.
Originally posted by: joedrake
lol @ ae
AE and Aeropostale are the only places I can find Medium dress shirts that don't look like garbage bags on me, unless I get lucky and find some slim fitting shirts at dept. stores, I have to get all my shirts from either or. STFU troll.
with that description, i am going to say it runs smaller as it sounds like its more of a fitted shirt
lol @ ae
AE and Aeropostale are the only places I can find Medium shirts that don't look like garbage bags on me, stfu troll.
Please forgive me master 🙁
You're groveling with a PPD 10 times that of mine? :Q
Thanks 🙂
If it doesn't fit I can always return it to an AE retail store.
lol @ ae
He should be. Nefing as its worst. =/
Too bad, not counting this post, I almost never nef - my posts almost always help the thread in some way.
I'd buy whatever size you normally wear. It doesn't sound like it'd be any bigger or smaller than a regular T-shirt, it's just cut differently. Like an athletic-fit dress shirt. I still wear the same size as a regular dress shirt.
