Need help with 3G
jbt52
87
Just got an iphone 4 with 3 G, but when I try to use anything (Maps, Email, etc) it says I need to connect to Wifi. Isn't this the point of 3G? I never had to do this on the Droid with my 3G network. Didn't switch carriers or anything, just phones.
Ka0t1x
1,724
This sounds odd..Like its not seeing you have a data connection. Does it show an E/3G next to your carrier at the top?
You could try flipping airplane mode off/on.
alent1234
3,915
Worst case run the battery down to 0 and then plug it in. It's a hard reboot. One time on my old 3GS I couldn't connect to 3G or two days until I did this
wantedSpidy
557
Settings -> General -> Network -> Enable 3G and Cellular Data should be on. '3G' should appear next to your carrier name.
jbt52
87
It does show 3G at the top, I will try a hard reboot as well, and I double checked the settings, Cellular data is on but I saw no setting for Enable 3G ...
jbt52
87
Yes, also tried flipping airplane mode on/off but didn't notice a difference
Redfraggle
2,413
This might sound odd, but you did get a data plan right? I wonder if they messed up something with your plan?
jbt52
87
I am on the same plan I have been for 10 years, didn't change that at all. I am actually still having the same problem too since I was going to try a hard reboot and I still cant wear the dang battery out on the thing LOL so as of yet, no fix
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
If there is an Apple store in your area, take it to them, and walk out with a replacement.
Tyranicus
914
Not possible, at least not on AT&T (I'm not familiar enough with Verizon's service.) The iPhone has its own separate data plan.
jbt52
87
No, same plan. I had an unlimited data plan on my droid and simply upgraded to the iPhone without altering my plan at all. Thanks Emulex I will check that out!
