need help with 1 more algebra problem
coder1
Ok, I have no idea where to begin on this one?
Determine the value of k such that kx^3-x^2-5kx+12 is divisible by x-2
Am I suppose to use synthetic division? Thanks for any help.
Can you point me in the right direction? is k suppose to be the constant. thats what is throwing me off
Originally posted by: coder1
So I could set k as any value and the results would be the same?
The idea is to find a value of k that satisfies the situation, so arbitrarily picking one is not a good way to do it 🙂
While you could use polynomial division, there is an easier way... If f(x) = kx^3 - x^2 - 5kx + 12 is divisible by (x - 2), then x = 2 is a root of f(x). Thus f(2) = 0. Should be pretty easy from there on...
Ok. Since you know that x-2 is a factor of the expression, substituing x = 2 in the expression would make it equal to zero. So doing that will give you:
8k - 4 - 10k + 12 = 0
2k = 8
k = 4
Voila!
2k = 8
k = 4
Voila!
Ding ding ding! I was about to say...no need for synthetic division here, good lord.
algebra.... thats one of those things you forget after surface and vector integrals. All of my friends agree that after taking years of calc, you have no idea how to do stuff like that
actually, its pretty sad if you've taken calc and can't figure that one out
yes. you should be able to do that in your head.
Sometimes it's the way the question is set up. I don't think he meant Algebra in general, because that's sad 🙂
It's not algebra problems that most of us forget in calc, it's the geometry. At least thats how it is with my friends.
