I posted this at another forum earlier, but I only got one response and it helped none.
First off, I got a HIS 9800pro yesterday to replace my old GF2. Removed the nvidia drivers, updated BIOS, and put in the ATI. After installing the Catalyst drivers, I see that my font and icons are very blurry, which never happened on my GF2. Uninstalled Catalyst, put in Omega drivers. Same thing. Then I installed XP in a new hd, to see if the problem was coming from some setting that I had changed awhile back. Again, after putting in Catalyst (4.6), the font is blurry, even on a new OS. Changed the dpi to 120, which fixed it to some degree, but not entirely. This doesn't happen in games though. So, has anyone had this problem, and if so, can it be fixed?
Secondly, my screen tends to flicker alot.. never happened with the older card. It will do it for about 20-30 seconds, then stop for about 5-10 minutes, then would continue again after that. I tested it with my old psu (350w PowMax which I got with my Enermax case awhile back), and flickered. Put in a 480w Thermaltake PurePower afterwards, and it does the same. It's really annoying, especially when playing games. It first started when I OC'd (only at XT speeds, 412/365), but it continues to do it at stock speeds. Is this the vid card, or the refresh rate on the monitor (CRT @ 85mhz, resolution 1024x768)? Or something else?
Lastly, which is bugging me the most, is that nothing seems.. smooth. When I drag screens around, the edges are glitchy, and don't move in a straight line with each other... just looks jagged. Are there any settings to change this? Or any program to fix it..? I never had any problems with the GeForce2, but ever since I installed the 9800pro, I've had .. well, not anything serious, but really annoying issues.
And for reference:
Athlon XP 1700+ @ 2.00ghz
2x256 OCZ PC3200 (2-3-3-6)
Asus A7V8X-X (I read that KT400 chipsets and ATi cards don't match well. I installed the latest BIOS and I didn't have the issues that other people mentioned (unable to install Windows, constant lockups in games, etc.) hopefully this is not it, don't want to spend 80+ on nForce2 mobo, short enough on money as it is)
Thermaltake 480w Silent Purepower PSU
Volcano 12+ heatsink (Temps are not an issue with this rig)
Also, I scored 5826 in 3dmark03 @ XT speeds, and 55xx at stock. Is that normal for a 9800pro? Scored around 31,500 on Aquamark OC'd and 29,500 at stock.
Things I have done so far :
Set AGP speed to 4x
Changed aperature size in BIOS (it was at 64, changed it to 128)
Changed dpi from 96 to 120
Turned Fastwrites off
Countless installing and uninstalling of drivers
Other things I have done and don't remember offhand..
And yes, I have checked that the molex connected is directly from the PSU, not jumped off from a fan or anything else. All voltages are stable..
Any help would be greatly appriciated! Sorry for the long post..
And for reference:
Set AGP speed to 4x
