need help thnaks
damn
220
ok i kinda new at computers i wanna knoe if i get a case will any case work or does it matter cause i saw a case but i dont know if it will fit my parts
SWScorch
9,520
Most cases these days are standard ATX cases, which will fit all ATX motherboards (pretty much any mobo made in the past 5 years). Most ATX cases should also fit mATX (microATX) motherboards, but a mATX case won't fit a standard ATX motherboard. So, unless the case you want specifically indicates that it is a mATX case, then you probably have nothing to worry about.
Stallion
3,657
I thuoght I read where new P4s need a different mobo tray that didn't come with older cases? might check it out if your buying a used(older) case and want to put in a P4.
