Need help - RPi solution for ELO et1545l-8swc-1 Touchscreen
haggggler
39
I've got a couple old ELO touchscreens:
http://media.elotouch.com/pdfs/manuals/008521_f.pdf
https://www.elotouch.com/1545l-disconti ... 2006.html/
They have the RS232 connections not the USB type input and no drivers for ARM. I've tried a couple different DB9 > USB adapters with no luck, but I wouldn't I still have the driver issue. Does anyone know if I can make this work. I might even be persuaded to give you one if there isn't a straight solution, but you believed you could create one.
Thanks for any direction
Is this the right forum?
Ken g6
Moderator
Dec 11, 1999
16,758
4,726
75
Do you at least have the display working? I found a thread in a different forum suggesting HDMI to VGA converters. That forum might be a better place to ask your other questions too.
The touch component has me stumped. They sure don't have drivers for RPI, and I don't see documentation on how it works either.
