need help...recommend me a tool to fix filesystem errors
DimZiE
1,093
title says it all....
been havin' problem's with hard drives recently so could u guys recommend me a good tool to diagnose n fix...
any help is appreciated
montag451
4,587
Any ideas what errors you are getting?
Try helping yourself out a little and put some more info out here.
What system?
MAC, PC, Iphone? What?
DimZiE
1,093
some part of the drive cannot be read... but chkdsk runs always pass with flying colors even with the /R option
corkyg
Elite Member | Peripherals
27,370
240
File corruption and drive faults (bad sectors) are two different beasts. Chkdsk will bypass bad sectors. Spinrite is worth a try if the data is important. But, you need to replace the drive.
Pardus
8,197
21
Backup everything on the drive first, then go to the manufacturers web site and run there diagnostic tools. Most will have a low level-non-destructive scan and a high-level high-destructive scan that will give you a error code if it fails. Then you can call the manufacturer with that code and have them replace it.
