- Nov 23, 2005
- 906
- 0
- 76
Hey guys,
My system is in the signature, the HP's 300W PSU runs it, but on a couple of occasions during a hard gaming session with NFS Most Wanted the system froze and after a couple of seconds came back as if nothing happened, also sometimes during Far Cry's Lan it freezes and reboots, first I thought it was the Gfx card's overclock but 3D mark's overnight loop ran fine. This led me to conclude that the PSU is slightly falling short, mainly in games that are both CPU and GPU intensive, otherwise the system is a model of stability in all other games and normal work.
I decided to get a new PSU, I found this
PS-FS400PA FSP Group ATX-400PA 400W 24/20 pin SATA Power Supply $29.10 Ewiz Link
This is an ATX 2.01 PSU, moreover it's a Fortron. But tell me if it would be enough for an upgrade to Geforce 8 whenever it comes out. I don't plan to add anything more to the system, except swap the gfx card. I mean the 300W falls short only so, I'm sure my current system at 100% load should draw about 320W MAX. So will the FSF 400W tide me through, give an opinions guys and quick.
Thanks
Thanks
