Need Help Plz. Dell Dimension 8100
shikimaru
Hi guys, I have a Dell Dimension 8100, and am looking to switch out the motherboard and replace it with a motherboard that can take DDR instead of Rambus or RDR. I want something that's fast enough to play World of Warcraft and cheap enough to keep some cash left in my pocket. Can you give me any suggestions ? or even pointers as to things to watch for to make the transition from one motherboard to another as smooth as possible? Thanks =)
Green Man
1,110
I don't know about the dimensions, but in the optiplex series you can't swap out for a standard system board.
You might end up buying a new case...which isn't too bad. Nothings as ugly as dell cases.
shikimaru
THanks for the reply man, I hope I don't have to buy a new case, but that may end up being the case... (no pun intended) Hopefully someone who has experience with my computer can tell me?
Dec 10, 2005
28,668
13,811
You'll need to buy a new case if you are using a retail mobo since it will not fit in the Dell case. As for the processor/socket type, I think it is Socket-478, so look for a board that uses that socket and allows for the use of DDR ram.
o1die
4,785
Ascendtech has a Dell 845pe board that might work with your case, Check the dimensions and backplate carefully. It's listed in pricewatch under motherboard and "dell".
