- Sep 4, 2005
- 1,615
- 0
- 76
Ok since this is my first overclock i have been reading for hours. So i understand it. I go into the bios and put the muliplier at x10 2000. I raise the fsb by 5. Now when i raise it to around 115. It shows the start up screen where it checks teh memory etc and then it stops after it says press the del if u would like to skip the oc and go to bios.. or something like that. It should be checking the the drives but it doesnt. Instead it restarts it self and then finds the drives and gets into windows. I havent raised the voltage yet and still 1.4. What should i do. Right now i can boot at 235 and sometimes can boot. If i turn off my pc for a moment it works and heat is not a issue. 30c with door off
