Need help on installing the front fans
prankster
44
Should I install the front fan to suck cool air to enter the case or to blow away the hot air from inside the case?
Thanks
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Under normal circumstances, the best way to do it would be to have the front fan suck air into the case. But you won't damage anything really, so you could easily try both, and see which works better for you.
bendixG15
3,483
You want maximum airflow thru your case.
The PSU located at the back of the case,
normally it blows air out of the case.
So, its usual to install a fan in the front
of the case to blow air into the case.
As you add more fans, you want to maintain the
max air flow thru the case concept.
You will now get 50 opposing posts :)
0roo0roo
64,795
84
suck in, unless you want it fighting the other fans. thats a battle it won't win
