Need help on build for a friend
Gadzookie
ok im trying to pick out parts for a friend of mines here is what i got so far
he is not going to over clock and will mostly playing games some light photoediting and burn cdr and dvds
Antec Solution SLK3000-B Black Steel ATX Mid Tower Computer Case - Retail 45.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16811129152
ENERMAX EG425P-VE SFMA 2.0 420W Power Supply - Retail 76.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16817103459
AMD Athlon 64 3200+ Integrated into Chip FSB Socket 939 Processor - Retail 190.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16819103502
ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail 132.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16813131530
CORSAIR 1GB (2 x 512MB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - Retail 81.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16820145440
Seagate Barracuda 7200.7 SATA NCQ 80GB 7200 RPM Serial ATA150 Hard Drive - OEM 68.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16822148040
NEC FD1231H-302 Black 1.44MB 3.5" Internal Floppy Drive - OEM 8.50
http://www2.newegg.com/Product/Product.asp?Item=N82E16821152005
NEC Black 16X DVD+R 8X DVD+RW 4X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM
48X CD-R 24X CD-RW 48X CD-ROM 2M Cache IDE DVD Burner - OEM 51.99
http://www2.newegg.com/Product/Product.asp?Item=N82E16827152035
Rosewill Radeon X800XL 256MB 256-bit GDDR3 PCI-Express x16 Video Card - Retail 289.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16814164041
Total 941.49
how does that look ? only thing is the motherboard i like asus alot has lots of good features is there anything better and cheaper ?
also how long do you think this system will last for gaming ?
thanks for all your help guys !
i like the chaintech one too but im afriad they wont release bios for future cpu suport
asus already does
hey the psu is nice im going to switch to that one
ok im thinking of this setup now
http://www.monarchcomputer.com/Merchant2/merchant.mv
Pre-Tested and Setup AMD Athlon 64 San Diego/Venice (939) Combo
Motherboard: 110480 - MSI K8N NEO4 Platinum Audio/GB-LAB/PCI-E/ $137.00
Processor: 120210 - AMD Athlon 64 3200+ 512K 90nm Rev. E Venice $199.00
Heatsink Fan: 130122 - AMD Certified Opteron/64/FX Heatsink $8.00
FREE Full DVD Version of Far Cry
FREE Napster Music Download for 4 Months
FREE Half Life 2 Full Version Coupon
Total $344.00
get the venice combo from monarch then get the rest of the parts from new egg
ENERMAX Whisper II EG465P-VE FMA(24) 460W Power Supply - Retail 75.00
http://www2.newegg.com/Product/Product.asp?Item=17-103-464&depa=0
Total 618.49
GRAND TOTAL 962.49
great system he will run it on stock and down the road if he wants to
overclock he can just get a better HSF and he will be all set
i went to msi webpage and i cant tell if the msi board suports the venice chip !
i dont know if monarch made a mistake :-(
Originally posted by: Gadzookie
i dont need a bios update for it to suport the new cpus ?
Usually, I think you do. Some may come from the factory Venice-ready though. I'm still not sure what will happen if you use a Venice core in a MB without a bios revision that supports it, but I think it'll probably boot and simply misdetect the cpu as a different core. If it doesn't boot at all, then you'd need a previous A64 chip to get the system to boot in order to flash the bios.
