Need Help on build : Core i5 3350P VS AMD FX8120
Discussion in 'CPUs and Overclocking' started by yodagamer27, Dec 12, 2012.
  1. The Alias
    The Alias Senior member
    Aug 22, 2012
    622
    26
    don't touch the 3350p if you're doing 3dsmax rendering and the 8320 is so close in price just look here :
    [​IMG]
  2. grimpr
    grimpr Golden Member
    Aug 21, 2007
    1,097
    7
    If you're gaming go Intel all the way.
  3. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    37,803
    1,674
    990FX is certified for SLI. 970 is not.
  4. SPBHM
    SPBHM Diamond Member
    Sep 12, 2012
    4,376
    120
    MSI H77 G43 - $104
    for this kind of money you can buy a z77 motherboard I think,
    anyway, the 3350p is a lot more efficient and better for gaming
  5. dmoney1980
    dmoney1980 Platinum Member
    Jan 17, 2008
    2,379
    10
    I'd still stick with the i5, better overall performance, especially for gaming
  6. AtenRa
    AtenRa Lifer
    Feb 2, 2009
    12,397
    1,202
    For the same price i would go for the FX8320, OC to 4 or 4.2GHz and you will be fine.
  7. inf64
    inf64 Platinum Member
    Mar 11, 2011
    2,779
    1,043
    Once pushed to 4.2Ghz(just a multiplier change,nothing else) the 8320 would be overall better chip than 4C/4T 3.1Ghz i5. But it's up to OP to decide,there are pros and cons for each setup.
  8. SPBHM
    Sep 12, 2012
    4,376
    120
    it really depends on the usage,
    the even lower clocked 3330 can keep up (and beat) with the 8350 (4-4.2GHz) for gaming, with the lower power usage and requirements
    http://www.hardware.fr/articles/880-15/jeux-3d-total-war-shogun-2-skyrim.html
    now for other applications (like rendering, as the test shows) the FX would make more sense,
  9. inf64
    Mar 11, 2011
    2,779
    1,043
    Yeah I agree. Which ever is cheaper should be his pick.
  10. sm625
    sm625 Diamond Member
    May 6, 2011
    8,175
    134
    An i5 3350P will consume about 1 less kwh for every 12 hours you spend gaming. So if you game 20-25 hours a week you're looking at about $50 saved over the course of 3 years. So you'd have to be able to build the AMD system for $50 cheaper in order to justify the added power.
