Need help OCing barton 2500+
fsstrike
My friends 2500+ is OCed to a very stable 2.1Ghz with a FSB of 200 with 10.5 multiplyer. We are using the Zalman Pure copper fan, i think its called the 7000 or something. Neways, When we up the multiplyer to 11 the thing freezes once you get inside windows. Is this because its overheating, or do we need to increase the voltage? The current voltage, stock, is at 1.7. I personally think we are just doing something wrong, and i belive that it can OC to 2.2 considering that 2.1 is running so well.
Specs
AMD Athlon XP Barton 2500+
Asus A7n8x
Radeon 9800 Pro
512mb DDR 400
Bump it up to 1.75v. Mine is the same way,... it's fine at 2.1 but 2.2 needs 1.75 for stability. You may also find it needs 1.775, 1.80 or more....
Mark
