I just recieved my drive from compusa and installed it. I tried burning something using Nero, easy cd creator, disk juggler, clone cd, and fire burner. For example when i try creating a cd in easy cd creator it says "There are no supported CD-Recorders available. Ensure that your CD-Recorder is powered on and that all cables are properly connected. You may aslo need to update Easy CD creator to recognize your CD-Recorder. To update Easy CD Creator select Web-Checkup from the internet menu.
The weird thing is when I goto cd information it shows me the properties of the iomega drive. This drive still has the 1.06 firmware, might this be the problem? I was gonna flash to 1.07 and do the name change but while i was reading the directions it stated that you drive should be working before you do the name change. Right now my drive does not seem to be working. Can someone please help me
