You Europeans and your fancy, stylish radiators. In the States, you can only become a plumber if you fail a design test, so most supply houses only give you the choice of ugly or really ugly.![]()
the radiator close to the heater is quite a lot warmer than the one in the bedroom, 15 feet away; i'm pretty sure the boiler only makes hot water, not steam. it's a cheapo Ariston e-combi, and it looks like it maxes out at 90c.
i can't find the bleed valve either on any of the radiators. maybe there is one for the whole system?
btw, the windows do not feel particularly cold to the touch. they are also mostly double-glass.
It does appear that radiator could have 2 chrome flow valves at the base (you want more flow in the cold room) and a capped bleed valve at the top of the radiator
But we are quickly approaching the need for a pro to check as the underlying plumbing and circulation has many factors
