F fzkl Member Nov 14, 2004 179 0 0 Jan 1, 2007 #1 I picked up the corsair memory mentioned in the signature. Without opening the heat spreader, how do I check if I have a Promos or a Micron DRAM? Overclocking will probably tell me, but is there any other way to find out? Thanks,
R RiBeNtRoP Junior Member Dec 29, 2006 23 0 0 Jan 1, 2007 #2 Try with a program called Everest, or just by searching on the internet the code that your ram must have impressed on it.
