Question Need Help For My First Build | AMD R7 2700 | 1060 6 GB
Priya Patel
11
I need suggetion and Help my New Build:
Here is My Configuration which i want to buy.
confused to selection buy Case(Cabinet).
My Spec:-
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (Item model number :- YD2700BBAFBOX) with Included Components : Processor, CPU Cooler
Motherboard: Gigabyte B450 Aorus Pro WiFi rev1
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage (SSD): Western Digital - Green 240 GB 2.5" Solid State Drive
Storage (HDD): Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac - Zotac Amp Edition GeForce GTX 1060 6GB DDR5 PCI-e Graphics Card with IceStorm Cooling
Power Supply : Corsair VS550 550-Watt Power Supply
and here Confused with Cabinet :-
im not willing to spend too much on Cabinets
Here are Written Case Names and Link which is good looking and lower Price.
1) Corsair - SPEC-01 ATX Mid Tower Case
2) CHIPTRONEX X410B MID TOWER GAMING CABINET CASE USB 3.0 WITH LED FAN WITHOUT SMPS
3) CHIPTRONEX Ghost GNX200 Mid Tower Full ATX Gaming Cabinet with Matte Glass Front and Top Panel/Transperent Side Panel with 3 LED and Fan Controller
https://www.amazon.in/dp/B078Z6ZJGQ...&pd_rd_r=5ac32ade-0b36-11e9-8210-ed08ba772cb1
4) CHIPTRONEX GX1000 V2 Mid Tower ATX Acrylic Side Window Gaming Cabinet with 2x120mm Red Led Fans, 1x120mm USB 3.0 Normal Rear Fan with Speed Controller
https://www.amazon.in/dp/B075V7FZ63...&pd_rd_r=5ac32ade-0b36-11e9-8210-ed08ba772cb1
5) BBC Gaming Cabinet 8804 With 3.0 USB And Side Acrylic Panel Without Power Supply
https://www.amazon.in/gp/product/B075CQRD4P/ref=ask_ql_qh_dp_hza
Tell me which is supported cabinet for Configuration.
and yahh , i Also work and Gaming for 8 to 10 Hours a day, does it need liquid cooling.? or it'll be fine with AMD Cooling Fan.
because i want to add Liquid cooling in future,
Corsair or Cooler master Double Fan RGB
cooler master masterliquid 240 rgb liquid cooler
or maybe
Corsair Hydro Series CW-9060025-WW Liquid CPU Cooler (Black)
So here is my Question and i need help with tha.
1) Does my Motherboard Support this liquid cooler?
2) also i need a cabinet like that which will support my selected spec, and liquid cooler in future.
3) alo confused in selecting Graphic card.
someone suggested me to buy
Gigabyte GeForce GTX 1060 6 GB Graphic Card:-
https://www.amazon.in/Gigabyte-Geforce-Gtx-Video-Card/dp/B01JNUO6BG
Which is better Video Card
This Gigabyte or Zotac gtx 1060 6gb (Which i mentioned in my Spec)
4) Also, did i select a Good PSU of Corsair 550W.
IF not, suggest me good PSU with minimum range.
5) Does it have any Problem, i will add 16GB ram more next year.so..
My Location is : Ahmedabad, GUJ, India.
prtskg
261
94
101
UsandThem
16,068
7,383
And corsair vs and cx series arent very good. They use cheap Chinese capacitors. You can use gold series.
Please tell later if that ram works with your motherboard at rated speeds. Would like to know.
Also games are free with some gpus right now. Hope you know that before you buy.
The new versions of the CX-M series (since 2016) don't use "cheap Chinese capacitors". They mostly use Japanese capacitors (especially in the critical areas), and the units are very good as a basic bronze power supply, and there are a lot worse choices out there. Now the VS is a no-frills entry-level unit, and one that would a unit many people should skip as long as they can afford a better unit.
https://www.tomshardware.com/reviews/corsair-cx750m-psu,4799-3.html
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=486
It all comes down what the prices for the better gold units are in the regions where people have to buy them. At the right price, the CX series could be a good choice. However, if the price difference is like it is here in the U.S., it makes sense to spend the extra $20 for a really good gold unit.
Priya Patel
11
Hi, fellow Ahmedavadi, have you tried these sites -
https://mdcomputers.in/
https://www.primeabgb.com/
https://www.theitdepot.com/
https://www.gurushreecomputers.com/
You'll get better deals there.
Hi, Are you also ffrom ahmedabad??
Priya Patel
11
So here i got very good response, i like it.
so my PSU confusion is clear.
can you guys please, solve me my other quatiion confusion?
Please.
UsandThem
16,068
7,383
but which Graphic card will be fine,
i mentioned two video card.
one is Zotac and one is gigabyte.
which will be better graphic card.?
Either one would be about the same quality-wise. The Gigabyte has a back-plate if that's important to you, and the Zotac doesn't.
Outside of that, flip a coin to pick the winner. They have the same rating on user reviews as well, so there's just not enough difference between them to say "this one is clearly better".
https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1060-amp-edition
https://www.gigabyte.com/Graphics-Card/GV-N1060WF2OC-6GD-rev-10-11#kf
Reactions: Priya Patel
Priya Patel
11
what is the price difference between the 2 cards? is price important?
Zotac gtx 1060 6gb amp edition ice strome cooling (double fan) :- INR 25,500 - $365.67
and
Gigabyte gtx 1060 6gb Double fan :- INR 27,500 - $394.35
Price Dosent matter, but if there is no issue of perfoamance or any problem.
Iron Woode
31,371
12,860
and
personally I would get the Gigabyte especially if it is a Windforce model.
Priya Patel
11
Gigabyte Geforce Gtx 6GB Video Card
please chehck and tell me is it, windforce oc?
well, whats diffirence between windforce and windforce oc??
does it support 4k Videos and Gaming?
i also see that, in the Zotac card there's 4 HDMI pins and in this Gigabyte there's only 2 HDMI Pins.
well, i will attach two display maybe, not four.
Iron Woode
31,371
12,860
windforce is the cooling. OC just means Over Clocked.
It is not meant for 4K gaming. 1080P is where it works best.
Priya Patel
11
okey, so i fine with Gigabyte.
can all the componants perfactly fit in this cabinet??
or should i go with Corsair 100R?
becase in future i will fit double fan liquid cooler.
i also listed other cabinet in my post, please check it.
Iron Woode
31,371
12,860
seems like everything should fit in there.
always check reviews to be safe.
