Need Help Finding Replacment MOBO!!
Nebakanezzar
Hey all,
I have a celeron 300a with a abit bh6 (i think thats the model) mobo. the mobo took a dump and i cant seem to find anyplace that carries any mobo i can use to rplace it. can anyone direct me in the direction of someplace that might carry a slot 1 mobo for a celeron 300a.
thanx.
p.s. i am in southern cal (orange county) if that helps any.
I couldnt personally recommend that, I would take it as a sign to at LEAST upgrade to a Duron or modern Celeron. I'm sure you could grab a mobo/cpu/heatsink combo for under $100.
For old parts, the only economical route is usually eBay. With the lower sales volume on old components, buying it new will cost you as much as a current economy mobo/CPU combo.
