Need help finding mid-tower
DerwenArtos12
4,278
The kublai is a very good case and you can move the hard drive cage to either the top 3, middle 3 or bottom 3 5.25" bays. I really think that case will suit you best without getting into a rather expensive case or one with an odd layout.
Zepper
18,998
I'd vote for the KL02B - see my review of the KL01 with reference to the KL02B here: http://www.TechIMO.com/articles/. All drives can be added/removed from the front. SATA hard drives can be made hot plug/swappable. It comes with one hot swap bracket and others are available for about $5. each. They are both respectable cases with some unique features.
And if it becomes too hard to work around the drive cage with your video card, you can move the CP05 hot swap connector up or down the cage, or the whole cage can be moved up the rack and out of the way. That's the one advantage of a stacker type case, flexibility of drive location.
If you don't mind paying a lot less, take a look at the Rosewill R5605:
http://www.newegg.com/Product/...x?Item=N82E16811147083 - I reviewed this also as the 5604 version here: http://www.TechIMO.com/reviews/ in the Cases section under Yeong Yang/Rosewill R5604 at the bottom of the list (Yeong Yang OEMs for Rosewill). IMO, one of the top cases under $100. - 11" of clear card space.
And the Lancool/Lian Li PC-K7 is an option as well:
http://www.newegg.com/Product/...x?Item=N82E16811112154. They are currently OOS at the Egg, but smart shopping can beat their price anyway.
.bh.
And welcome to the AT forums.
Zepper
18,998
Tip: if there is a silver version of a case that you are going to link, please choose it instead of the black as one can see the details more easily on the silver versions. No silver version of the K7 yet...
The K7 has a 3.5 external bay and more HDD bays. The ports module is a one piece thing that could be moved to a bay filler plate quite easily - two screws.
.bh.
