Need help finding an adapter cable
rudeguy
47,351
14
61
I'm looking for a male s-video to male component video cable but I can't seem to find one.
My googling skills have failed me. Can ATOT rescue me?
zinfamous
111,863
31,354
blue jeans cable?
monoprice?
they don't have these?
...also sounds like something radioshack might have.
rudeguy
47,351
14
61
blue jeans cable?
monoprice?
the shack!
If I do go there...I swear I'll play the old 80's song.
"LOVE SHACK IS A LITTLE KNOW PLACE WHERE.....WE CAN GET TOGETHEEEEEEERRRRRRRR"
PottedMeat
12,363
475
"6FT S-VIDEO 7-PIN TO 3-RCA RGB COMPONENT ADAPTER CABLE" on google shopping -> ebay
looks like male-s and male component - is that it?
Possessed Freak
6,045
Why in the hell would you do that?
I guess you could take RF all the way to HDMI but it is still going to look like RF.
[edit]Oh and you need a converter box to convert between S-Video and Component[/edit]
techs
28,559
4
the Shack?
Terrible name. Though it does bring to mind the proper image of their merchandise.
rudeguy
47,351
14
61
Are you sure?
I thought component was analog?
sdifox
100,290
17,904
no such thing.
S-Video is carrying Chroma and Luma in 2 different conductors while analogue component is Y (luma + synch), Pb (Blue - Y) and Pr (Red - Y).
A cable will not be able to derive chroma from those 3 signals.
SKORPI0
18,482
2,418
no such thing.
6FT S-VIDEO 7-PIN TO 3-RCA RGB COMPONENT ADAPTER CABLE - $2.90
Converts 7-Pin S-Video source to 3 RCA RGB component output
:hmm: So what is this then?
AMDZen
12,589
no such thing.
This
Demon-Xanth
20,551
You won't find a component cable. That requires and active adapter. You can find a composite cable though.
Just because something is analog or digital doesn't mean that a cable can be pinned out to make it work. (unless you're in a movie, then you can make a USB to S-100 bus with some paperclips and chewing gum)
sdifox
100,290
17,904
That ebay seller is an idiot. Hopefully people don't fall for that, that is for video cards.
S-video cables have 6 pins and a block like so:
lulz, the 2 next to the plastic peg are not pins, they are indentations like the one on the "top" part. Guides so you don't plug it in wrongly. Also serve as retention crevice. The socket has "spring loaded" mechanism for those slots.
SKORPI0
18,482
2,418
You're right, they are for video cards.. like the one I got with a PNY 8800GTS 640mb video card I got +3 years ago. Got terrible HD video (transport stream) from my card to the 32" CRT HDTV I had. Thanks for the clarification.:\
