Need help finding a particular wifi card
AStar617
Hi, I need a wifi card for my Toshiba Libretto, but it is very important that the card's antenna stub have as short and flat a protrusion as possible. In fact, very flat is more important than very short. This is because the Libretto is basically devoid of any useful ports, and I need to put the wifi card in the bottom slot so that a cards with larger protrusions (like fullsize ports) can fit comfortably on the top slot without having to give up network connectivity.
Does anyone have any personal experience with a pcmcia card that would suit my needs?
Thanks!
I've an SMC EliteConnect card, Model Number: SMC2532W-B that fits those requirements exactly.
It's an older card, B only, and quite possibly out of production. Their updated version, the SMC2536W-AG looks like it would work; but I cannot claim personal experience.
Honestly, functionality is much more important than speed. Hell, I'm lucky this Libretto even supports WiFi--the model immediately older than mine only had 16-bit non-Cardbus-compliant slots! 🙂 That would mean no USB either.
I will look into that model... thanks phisrow! :beer: Any other suggestions still welcomed with open arms. 🙂
OK, I investigated the SMC card, and I think that's some extended-range model that still sells for abnormally high prices. I'll be keeping SMC in mind for other models tho...
Bumping this up for the Sunday evening crowd.
I can't help you with the PCMCIA card like you asked, but have you ever considered a USB adapter? You do have USB right?
The disadvantage with USB is that they stick out, but you can easily unplug it and put in a pocket when not in use.
After getting a USB adapter, I just don't see the point of getting anything else as the USB you can use just about any laptop or desktop.
