Need help deciding!
ch33zw1z
39,838
20,433
Originally posted by: aigomorla
heh so all you had was a bad mount. :p
i usually do 3 mounts to make sure its good.
So far. I think I can get them lower if I try again. Always takes 1 time to learn the HS :)
3 times though, bored much?
zagood
4,102
I'm going to go out on a limb here and say it was your rear exhaust that was holding you back. Try bumping it up to high to check...you may not like the noise but it'll let you know.
-z
aigomorla
21,136
3,674
no if you guys try it you'll see why i do 3 mounts.
you'll never get the same mount on twice. :p Theres a hint.
Seems like i need to show you whippersnappers why i do 3 mounts.
Evening out your coretemps across all 4 cores like so on a air sink is very difficult to pull off with 1 mount:
http://i125.photobucket.com/al...aigomorla/Capture2.jpg
do i get a pwn? :D
ch33zw1z
39,838
20,433
do i get a pwn? :D
What if your first mount is the best of the three?
Old Hippie
6,361
do i get a pwn? :D
:laugh:
