I had initially decided to buy the 580 (4200 NOK) and maybe find a way to use my HD5770 as a physics card (Anyone know if this is possible?), but it came to my attention that a HD6870 CF setup would be 1000 NOK less and give overall higher frame rates according to reviews. Frame rates isn't the only thing I care about however since after this purchase I don't think I will upgrade for at least a couple of years. So realizing that this might be a difficult question to answer, how do you think each of the setups would do against future games?
I have never done a dual GPU setup before so I really don't know if there are any possible problems or if you have to use a lot of time to make it work etc. Any experiences?
I plan to use it (@highest possible level of detail) for World of Warcraft, Starcraft 2, Mass Effect 2, Diablo 3, Crysis, Bad Company 2, Photoshop, watching Blu-ray and probably a few other new games the next 2 years.
I have never done any overclocking so I don't plan on doing that now, but I might do so after a year or two.
Screen resolution: 1920x1080
Motherboard: Asus P6X58D Premium
CPU: intel i7 950
PSU: Cooler Master SilentProM 850W
Don't remember the exact dimension, but I have a big tower so I don't think space will be a problem
These are the two possibilities I think is best for me, but I'm open to other suggestions as well. Any input would be much appreciated 🙂
CPU: intel i7 950
