TerranForces
Banned
HI, I have an old TV that used to be top of the line. I got it from school. All they told me was that it cost $2200 and had these specs. I believe it is the Zenith 47 presentation series
36"
Front VGA is 800:600 60hz
Rear VGA does up to 1600:1200
Native Res is 1024:768
560 Scan lines
What exactly does this all mean. I am going to be setting up my XBOX360 to it and the reviews say that HDTV is really important to see all the details on it.
If I hook the 360 up to the VGA and set it 1280x768 will it be any better than if I just plug it into the Composite Cables. Is it worth the extra money for the VGA Adapter?
If I do use the composite, should I set it to 480P or 720P. It looks like it should be in between, but there is no setting for that. If I use the VGA, will that give me 720P HD quality, or will it be downscaled? Can I go any higher on the VGA if my TV supports it?
I really appreciate the help.
36"
560 Scan lines
