Originally posted by: nerp
I didn't mean to offend and I never said "kiddie porn" i simply said porn and that was a pretty tactless way of saying that hiding a volume isn't really effective at keeping it from someone who is really bent on retrieving your data. I meant to suggest that if you're serious about protecting data from prying eyes, sophisticated encrpytion should be priority one.
Why not just use something like 7zip ?
Its simple, can be very fast if you set it to store for the compression option.
It will hide the contents of the file including filename.
The encryption is also very good. AES-256bit.
The same encryption used by the NSA.
Wouldnt a hidden volume do this? If encrypted using AES/Twofish, how the hell could it realistically be decrypted? Assuming password strength.
