Help!
My problem:
For every 3 seconds, the game hiccups for a split second.
What I've tried to do to resolve the problem:
1. Reduced processes in Task Manager(CTRL+ALT+DEL) from 24 to 17-no improvement.
2. Originally running at 1024x768 w/ no AA or AF. Then ran at 800x600 and set everything as "Low" in the advanced screen- no improvement.
3. Fast writes are turn off-no improvement.
4. Refresh rates were set at 85HZ and 75HZ-no improvement.
5. 9500 Pro has been oc'ed to 294 core and 294 memory-no improvement.
6. XP2100 oc'ed to 1810Mhz and still no improvement.
I understand that this game is very CPU intensive and being that I have only a XP 2100, I hope this is not the issue. Other than my CPU, I feel that I have adequate components to run this game seemless @ 1024x768 w/o AA or AF. I also have 1024 megs of DDR2100 (CAS 2.5) and I'm running the latest Omega drivers. Physical memory in the performance tab of Task Manager shows that I have approx. 776000k avail. 549000k system cache.
Can anyone offer any suggestions?
Thank you!
My problem:
Thank you!
