Need help cleaning cpu.
quique55
Banned
Oct 7, 2004
1,035
Basically I want to know what is the best and most efficient way to clean the cpu without bending any pins. I do not know if this is the right forum for this type of inquiry. I figure since it is CPU related might as well start here. If it matters it is an Athlon XP 1600+. Thanks for any help.
Super6
1,054
I'd spray it with carb cleaner and after it dries use isopropyl alcohol to clean up the remaining residue.
Super6
Pohemi
10,964
17,145
By the way, there really isn't a need to be using dielectric grease on your processor pins...;)
boyRacer
18,569
maybe he had one of those fancy vapochill or prometia rigs... :eek:
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
on an Athlon 1600??? Hey whatever floats your boat.....
