Need Help Building PC
wsw
14
hello people... i'm new.. this is my first post...and unfortuneatly i need help.
Trying to build a PC for the first time. Please remember I'm on a Tight Budget
Already Bought:
CASE: Comet Mid ATX 300Watt
RAM: 256MB PC2100
HARDDRIVE: Western Digital 40GB 7200RPM
Looking to Buy:
CPU: Athlon XP 1800 CPU (i don't know what to buy.. Retail or OEM version)
MOBO: ECS K7S5A
What else do I need? Thanks for the input people =)
EKAtBzboyz
323
difference between oem and retail is retail includes a heatsink and oem does not
i would say go with retail becuase i dont think you will be overclocking and the retail heatsink should be good enough
ifyou buy oem, you will have to buy an aftermarket heatsink which for a decent one will cost pretty much the same amount as if you buy retail
that motherboard is a pretty good one
not too good for overclocking (but you probably wont be doing so anyways right?)
what about sound card? (or are you going to use onboard?)
what about cdrom/cdrw/dvdrom? (only need 1 of these, more than 1 are extra of course)
floppy drive?
video card?
//edit
modem?
it has onboard lan so no need to buy a nic
wsw
14
thanks eKatsbzboy...i was gonna use my sound card from my present computer for now... and a video card i'm lookin at a generic Radeon 7000 64mb AGP w/tv out... got any ideas on that?
EKAtBzboyz
323
well is ati radeon 8500 out of the question?
its not that much and much better (features and speed wise)
or maybe go to nvidia?
nvidia geforce 2 ti is a pretty good card
if you can get geforce 3 ti200 its also a good card
if not 7000 is a decent card
maybe compare reviews between some of the cards i listed and find one that you can afford and like
