GamingDaemon
Hi,
New member here. After building one gaming machine with an Intel Dual Core and some budget components, I have learned some hard lessons. So, I want to cobble together a new gaming rig using some of the parts of the prior one.
I am looking for suggestions for the new rig on the following items:
1) A case under $100 (had used a TT Soprano)
2) A mobo under $100 that has at least 2 Sata II 3GB/s slots and uses 240pin DDR2 667 memory, though I would be willing to spend a little more here.
3) A processor (let me guess...uhhhh...AMD 🙂 should I consider Intel?)
4) Video card. Should I use the existing Sapphire Radeon X850 XT PCIe (just bought it actually), or switch to a different video card?
One thing that really concerns me is that I want to be able to upgrade this rig over the next two (2) years so that I can still play the next cool PC game. I want this investment to pay off for a while. Is this possible?
One of the things I am concerend about is the new AMD AM2 socket or the new Intel Conroe chip coming down the road. If I don't have these chipsets or sockets, will I be hindering my ability to upgrade in the future? How long will I be able to play the cutting edge games?
TIA...
~Andrew
TIA...
~Andrew
