I just bought a new monitor and I unplugged the old monitor from the vid card and plugged in the new monitor. When I booted, I heard a long beep and nothing showed up on the monitor. I unhooked the new monitor from the vid card and plugged in the original monitor I was using and when I booted basically the same thing happened, a long beep and nothing showed up on the monitor, not even the POST. The only difference is that with the original monitor hooked up the computer will load Windows. I can tell from the hard drive activity and because I can shut the computer down using the correct Windows keystrokes. With the new monitor hooked up Windows doesn't load and I have to turn off the PC using the power button.
Sind the POST doesn't even show up I'm guessing it's not a problem with Windows. My guess is there's a problem with the vid card. Can a monitor hose a vid card?
One other thing to note is that before I shut my PC down to install the new monitor I went to Windows device manager and uninstalled the old monitor. But I don't think this should have done anything wrong.
So what can I do? I don't have another vid card that I can swap in.
