Need help benchmarking a image resizing tool (CPU and GPU)
24HZ
52
CPU: i7 990X(stock) - 22 secs
GPU: Geforce GTX Titan (stock) - 10 secs
Hey Lonbjerg, a few of us are perplexed as to why your Titan is being tied and even losing to a 470 and 660Ti respectively. Can you re-run the tests and take note of CPU utilization and GPU utilization? Just curious if the Titan is being held back by the CPU potentially.
Edit: Page 2 colorful chart!
24HZ
52
Also paging anyone with a 7970GE and a high end Intel CPU to the party.
Majic 7
668
2600K@ 3.8 27secs
Titan stock 9secs.
CPU 100% on all logical processors
22 to 28% GPU usage. 56% power
SPBHM
5,077
440
I tested on 3 of my home PCs
i3 2100 3.1GHz, DDR3 1333
CPU = 65s
with GPU (5850 755/1100) = 23s
now you should probably ignore both, because it will damage your graphic :biggrin:, but here it goes:
Athlon 64 X2 2.42GHz, single channel DDR2 600
CPU = 212s
Pentium T4400 2.2GHz, single channel DDR3 800
CPU = 190s
Lonbjerg
4,419
i7-990X 6C/12T 12MB = 22s
i7-2600K 4C/8T 8MB 4.5GHz = 23s
i7-3770K 4C/8T 8MB = 24s
So what does Sandy bridge and IVY bridge fail too
Not so hard...but then again...those are NOT Intel's flag ship CPU's, that would be an i7 - 3970X 6C/12T 15MB
Nice try :)
BallaTheFeared
8,115
i5-4670k + 7950
CPU @ 4800MHz
GPU @ 960MHz
MEM @ 2400MHz
7 Seconds, better than the movie! (Down with Nvidia!)
I'm sure I did something wrong, let me know what and I'll correct it and rerun it tomorrow when I have time.
SPBHM
5,077
440
Windows XP FTW?
10s faster for the CPU only test?
GPU was 3s quicker on windows 8 (but I'm using 2011 drivers on XP, since AMD dropped XP OpenCL support last year)
it's the same version (latest)
bvdeveloper
Hi all,
Thank you for the interesting read. I'm still reading everything but it will probably help us in making the gpu support better.
If there are specific questions feel free to ask, I'll see if I can find the time to answer them.
greetings,
The Benvista developer who wrote the gpu code
May 11, 2008
23,264
1,567
Here is my score with my AMD A10-6700 APU :
APU is 3,7GHz(turbo 4,3GHz) + HD8670D
Everything is at stock setting although i have the turbo core function enabled.
GPU accelerated : 35 seconds.
CPU only : 1:02 seconds.
BallaTheFeared
8,115
lol I forgot about this thread, graph needs to be updated though.
Should be a short red line across the top ;)
