My friend laptop running win2k is tossed, he download too much "stuff" and infeced with IRC trojan..
Explorer.exe Freeze after logon & I can not access within the OS, both mouse & keyboard do NOT respond.
I try all mode windows & no luck. So I view his laptop registry remotely from my pc (using regedit to connect network registry)
And found some trojan, virus & parasite infected in the laptop residing in the registry & different folder
Then, I try to use Norton Systemworks CD and run NAVDX.exe (Norton Dos Virus Scan Utitlies) but realize that it does NOT support NTFS
Any suggestion ?
Particularly need someth virus scan software that can scan NTFS File under dos envirnoment...
Pls advice, thanks in advance.
Any suggestion ?
