it needs some investigation, but it might be your CPU holding the performance...
how clean is your Windows install? some background service/malware could cause poorer performance.
also disable vsync...
something I can recommend when you have an unbalanced system is to use a framerate limit, like 30, 40FPS... using DXtory,
it helped me a lot to play skyrim smoothly
