Need Car Audio Advice
0roo0roo
64,795
84
noisy cars those civics, wind/road noise that is. not sure i'd ditch the rears.
True. I'm probably not going to be doing any dynamatting either. I don't know, I could just replace my rears (maybe with the type R). That would be the simplest solution. Then maybe down the line add a mono amp and subs. I don't know if an 8 inch will suffice.
get a sub first, anything is enough to fill, unless you want the neighborhood to know your there, but thats not sound quality:p replace blown speaker, leave others to replace if still disatisfied
I am confused with your response lol. Sorry
priority #1 replace blown speaker
priority #2 add sub
then deal with replacing the rears or whatever you still think needs to be done. the low end rounding out sound doesn't work so well no matter the quality of speakers in a civic, theres too much road noise and door/rear deck speakers can't be asked to do that much anyways, so a sub is needed to fill in the low range.
NaOH
5,015
priority #2 add sub
Well if I replace the blown rear speaker, I would think that would be it. I don't think I would replace the rears. There's no point. But taking in road noise and the inadequacy of the civics ability to insulate, I think I'm going to just replace the rear speaker and take it from there. Possibly in the future daisy chain a mono amp with the current one and power a sub that way. Thanks guys
NaOH
5,015
Originally posted by: Preyhunter
That's a 2 ohm DVC you linked to, you'd have to wire the VC in series to obtain the 4 ohm load you'll need to keep the amp happy. You'd be better off getting an 8 ohm DVC and wiring the VC in parallel or a 4 ohm SVC.
Yeah I know, someone pointed that out earlier. So yeah, doing the DVC in parallel is a no go.
LS20
Banned
Jan 22, 2002
5,858
no big deal in doing a dual-coil sub in series. thats how my setup is... dvc 2ohm sub running bridged off an amp, with the other channels for front components
