Question Need assistance to have Infiniti Fabric running at 1:1
Mir96TA
1,950
37
I am trying to figure out why infinite
Fabric is not matching with memory
What do I need to do for FSB:Dram to run 1:1 ?
Links to CPUz info --> CPUZ
Thanks for the assistance
Mir :)
John Carmack
160
268
Look for something in the UEFI related to infinity fabric frequency and dividers. I'm not sure what brand board you have but on Asrock boards that's in the overclock section together with DRAM OC and XMP settings. On these Asrock boards, the auto setting does 1:1.
Mir96TA
1,950
37
As it has indicated in CPUz it Gigabyte B450 Arous Pro WiFi37D3EB69-1886-4162-9A5B-3B14944AF76E.jpeg
Infinity Fabric divider
John Carmack
160
268
I checked one of the Gigabyte systems I have on hand and the "System Memory Multiplier" is set to "Auto" and so is the "Infinity Fabric Frequency and Divider".
Mir96TA
1,950
37
I have manually dialled in following 3643EBBA-4637-45BB-BBFF-A4DEF7AC5583.jpeg3643EBBA-4637-45BB-BBFF-A4DEF7AC5583.jpeg
Mir96TA
1,950
37
I don't know what to do for coupled mode.
Before it was set for Auto, then I changed it to 1800, half of 3600
now 1900 set it up for half of 3800
Which is half of it.
I am not sure what do I need to match it ?
CPU Clock ?
VirtualLarry
56,587
10,225
CPU Clock ?
.... go back, and read the definition of "double data rate"? You're doing well, if you have 3800 RAM synced 1:1 with 1900 FCLK.
Reactions: Shmee
Shmee
8,313
3,177
I am curious what VSoC you are running for that level of FCLK? You will want to be sure it is not too high if left on auto.
Mir96TA
1,950
37
I got troll by CPU Z memory.
Zen Timings got me stand corrected.
Thanks Cake Monster
Mir96TA
1,950
37
I would like to answer you, however I do not understand what you are asking ?
Are you asking did I adjust voltage to VSoC ?
The answer is no. I dont know, if I need to or even know where that is.
Can you please share, how I can answer your question ?
Shmee
8,313
3,177
VSoC is the voltage for the memory controller, IF, etc, on the IO die for your CPU. Sometimes you will need higher VSoC than default for higher IF clocks, such as 1900MHz and higher.
From the post above, it looks like it is 1.1 Volts. That is fine.
Reactions: Mir96TA
Mir96TA
1,950
37
Understood.
Thank you
