Regarding the plumbing, I am doing this basement remodel under permit so the inspector oked my plumbing and it was plumbed according to a couple of books, including getting the proper drain pitch, pipe sizes, sweeps in elbows, etc. It all hits the house's main 4" drain just before the exit and I'm using an air admittance valve under the vanity to vent the whole branch.
I did it tonight, I bought 19 80lb bags to have a buffer of concrete and we used 16.5. We were probably a bit too sparing on the water so the floating was a bit of a bear but the final result looks pretty good.
Mixed them all with a piece of 6 mil poly doing the two man method with that. I saw it on youtube--it worked pretty well. I assume that mixing this in a wheelbarrow would have sucked, but the plastic method does a thorough mix in no more than a minute per bag. The hardest thing about it was screeding and properly floating it, actually.
Thanks for everyone's input! I didn't use any reinforcement at all. I did a final check at lowes for proper steel dowel pins and they had none suitable for this--all were way, way too thick, so I used nothing.
