- Sep 15, 2012
- 14
- 0
- 0
okay so i finally finished my build.. i just need one last simple advice.. I wanted to add fans on my build. My case is a phantom 410. and i have an H100 installed on the top of the case..  I want to add 2 fans for a push and pull setting on my h100.. so ill be adding 2 fans on the top of the radiator. I was wondering what would be the best choice of fan for a push and pull.. I was hoping to get something with a built in led lighting just for looks... but if theres non available.. then i can go with a normal fan.. hmm and another thing.. I read stuffs on how push and pull works and it seems like the fans that are pushing and pulling should be synced so if i need to change the 2 stock fans that come with the h100 i wont mind..
